MassBassin
- Joined
- Mar 21, 2009
- 26
I just bought an 1980 Evinrude 35hp motor with electric start. the motor didnt come with the ignition but i do have the plug that plugs into the motor for electric start. I also measured the voltage with the motor running and the voltage rises as you increase the Rpm. The voltage exceeds 20V which i assume is way to high and will damage the battery. What is the Problem?
Does anyone have the wiring pinout for the starter solenoid? this is how i have it wired so far.
Starter solenoid wiring:
red wire - pwr from battery to positive on solenoid
black wire - ground from battery to negative of solenoid
Do you know where the yellow w/red stripe wire on the soleoid goes to? Battery power or ground in order to start the motor?
thanks
thanks
