kungpaoshizi
- Joined
- Apr 29, 2013
- 221
Engine is a 76 Mercury 1150~
I believe I've located my startup problem.
It was intermittent starting, from no sound to full startup. Then a click started happening.
If I measure voltage from the battery, the wire harness is good, (when it works) volts/amps are good to starter positive.
But I've found, when I hit the ignition and it clicks, there's zero current passing thru the solenoid to the starter.
I assume this defective and needs to be replaced, or is there another thing I should check?
