starter wiring on 78 marcruiser v6
Dave in La.
anyone know the correct way to attach the white, yellow and red wires to the starter soleniod? This boat had filled up with water to top of starter and rotted the old soleniod off, trying to help a friend. I relly need to know which post does the red 8 gauge wire from the 20 amp breaker attach to. I may be wrong but white was starter soleniod inside post and y
  • ellow outside. Please tell me if wrong and what needs changed. Thanks<br />78, V6, Sea Ray mercruiser Cuddy Cab<br />Dave in La.
SpinnerBait_Nut
Re: starter wiring on 78 marcruiser v6
Hey Dave, welcome to iboats. Let's get this to where you can get your answers.<br />Moving to the I/O forum.
Don S
The 8 ga. red wire should go to the A terminal in the picture below. The yellow with red stripe goes on the B terminal. The D terminal is for power to the coil when starting.<br />White normally ran from power to the resistor wire going to the + side of the coil.<br />One other problem here is that Mercruiser didn't have a V6 in 78, so the wiring may be different.<br /><br /><br />
