Happy New Year to all!
I've just had the most enjoyable time removing the starter from my I/O.
The pinion gear was not kicking out but the starter spun. I noticed that there was some surface rust on the gear, and the ring gear felt a little "wet". The starter had acted up a couple of times this summer after the boat sat for awhile but once started would work fine.
I had pulled the outdrive last winter to check the alignment and there was no water in the bellows and everything was OK. Used the boat till Nov 07 and no water was leaking into the bilge from the coupler area.
Is it possible that over time (in this case 8 years) condensation can repeatedly form in this area and cause the drive to stick or should I yank the OD again and check the bellows to be on the safe side?
The boat is kept on a trailer.
I normally buy all my VP service parts from Marine Parts Express, but $308.00 for a #3860566 starter (VP OEM )?????.
This place is about half the price and is a NEW Delco. http://www.psepmarineparts.biz/store/volvo_penta_starter_motors.htm
There are a couple of other sites also that are in the same price range.
Is there a difference between VP's pricey starter and the others?
Thanks....
Thanks....
