Starters for 454's
f_inscreenname
Re: Starters for 454's
No. It could produce sparks that will blow you up. Also marine starters are better suited for their environment.
180shabah
Ditto!!
Sort of, You may consider a gear reduction starter, as I believe that they are sealed, so no spark risk.
Bondo, will correct me if I am wrong.:'(
DHPMARINE
With twin V8's and a 27 footer,I hope you find a good marine mechanic,and let him work on your boat.There are many things spark related and fuel leakage related that need tending.
You've got a whole lot of bilge area,and the wrong starter and some fumes ..........
I hope the newer/smaller starters are spark proof,but I haven't seen it in writting,yet.
Sounds like a great boat ! Enjoy !
DHP
tommays
Its not like and ARCO with a marine rateing cost that much to even think about useing something else
Tommays
This is a Gear reduction Starter,.... It's Totally Sealed by Design,+ Are Safe in a Boat..........
The 1 Tommays shows is a traditional starter,... It has Extra Seals,+ Plates to Sparkproof it........
This is a Permant Magnet Starter,........
I Don't Know,.... But I Don't Think they're Sealed........
Someday I'll take 1 Apart,+ See..............
