Starting "87" 70 hp Evinrude
svangui1
1st the motor runs fine once it starts. <br /><br />The problem is that whenever the thing sits for any length of time it takes forever to start up again. I am not a real pro with outboards but it seems like there in no gas readily available. I pump the ball and that does limited good and yes it is soft. There doesn't seem to be any problem at any speed once it starts.<br /><br />I have an inboard 20 gallon tank, the motor is a "87" 70 hp Evinrude. I don't see any leaks of any kind in the fuel system.<br /><br />Anyone got a place to start on solving this.
D
DJ
Guest
Re: Starting "87" 70 hp Evinrude
svangui1,<br /><br />Your engine has a "primer" system not a choke system.<br /><br />Turn the key "on" and push in the key and hold for 8 seconds, then turn engine over.
svangui1
djohns19,<br /><br />Thanks for the info, I will try that.<br /><br />Scott
