No need to pump it on a hot start. If that doesn't cure it, you might be getting some gas spillage into intake manifold after shutdown from heat perculation or a faulty carb. Assuming you have a warm-up switch the easiest way to start with that condition, is to open the throttle while cranking, and leave it there until engine catches, and then immediatly throttle back.
