Oldsaltydog
- Joined
- Jan 27, 2004
- 322
After looking under the SEARCH heading, I found the following responses. Let the motor sit a while with the throttle open, crank with full throttle, and then pull back on the handle quickly to prevent over revving.
(I have tried this method and it works.) Another more cumbersome suggestion was to take out the plugs to air out the cylinders. (This works on my chainsaw just fine.)<br /><br />How about another alternative of disconnecting the fuel line, turning the motor over 5 or 6 times to clear out the cylinders, and then starting the usual way. What do you think? Has anyone tried this approach?
