Starting a stood engine
gashead1974
Any precautions I should take if I wannt to try and start a early nighties black max that has been stud for some time (18 months)? Was running fine prior to removal.
Bob H.
Re: Starting a stood engine
You can spray some Marvel Mystery oil or similar product in the cylinders and let it sit a bit, rotate the flywheel by hand to make sure everything is moving freely before turning on the ignition. The rings may have taken a set by now but a few thermal cycles will bring the life back. You may want to replace the impellor too.
