Starting an OMC 5.7 GM out of the boat
fairshopperguy27
Picked up a project boat recently with the OMC 5.7 GM engine. I've pulled the engine out of the boat and it's on a pallet now. I'm trying to figure out how to jump across the main plug for the ignition to make spark so I can attempt to start this engine. I believe on the mercruiser plugs it's pins 5 & 6 that you plug in the jump wire. Is it the same on the cobra's?
going to assume its carbureted
take jumper cables from battery to B terminal on starter and block ground. take small jumper wire from B terminal on starter to coil +. take screw driver and touch S terminal to B terminal on starter. motor is now running. pull wire to coil to stop.
fairshopperguy27
I've got my 2-wire starter switch hooked to jump the starter. Isn't there a way to jump across the plug instead of running a wire across the coil?
fairshopperguy27
I used your coil jumper wire method. Thanks alot!
