Starting from scratch Oh boy
Tail_Gunner
Not to much experience here with this type of setup, 78 Glastron GT 150 675lbs dry weight add 400lbs total load 1000 lbs.
1977 Johnson 70hp 2 stroke 120 lbs compression on all three cylinders runs very strong. Turns a older 3 blade right to 6000.
I believe it a 2.25 drive ratio.
So I use turning points prop calc and it comes up with a 21, using a prop slip calc that gets 48mph@9% slip. That seems just a smidge high to me for some unknown reason. Any input here or experience would be appreciated
I will be using a 4blade aluminium probably Solas top end is of no value to me.
ahicks
Knowing what size this was would provide invaluable info...
"Turns a older 3 blade right to 6000."
In the most basic runabout/ski boat terms, 21+ pitch props are for sale everywhere because few setups will allow their use. 15" - 19" are hard to find, generally because they are the most popular. If I need to guess, it's likely going to be a prop in that range.
Tail_Gunner
17p that seemed right to me.....but she pulled hard the last 1000 rpm then just ran out of air. I just am reluctant to plop another hundred on a 20/21.
ahicks
To make sure I'm following. You're saying your engine pulled 6000rpm with a 17 pitch? And your considering a 20-21" pitch? If that's the case, I think you're going to be pretty disappointed with the 21".
What is your target max rpm?
Tail_Gunner
6000 for this outboard, after a bit of lurking ive found this boat commonly runs with 18/21 inches of pitch with 70/110 go engines. It can also achieve 49/55 mph speeds safely. Lol it took me by surprise actually both prop size and speed, I though of a name Buzzcicle
NYBo
I find it hard to believe a 70 can spin a 21" prop to 6000 RPM on a boat that size.
ahicks
Target rpm is 6K which you are already turning with a 17p, and your plans are to go with something in the 18-21" range to increase performance? Let us know how that works out for you.... Especially when using a 4 blade prop, with no priority regarding speed.
jimmbo
The WOT range for that engine is 4500 - 5500. It is not going to make more power at 6000, it will in fact be making less and will deliver a lower top speed. Gear ratio is 29:12 which would be 2.41:1. A 17, possibly a 19, would be about the correct choice for that boat, Does it have power trim? Is your tach accurate. and set correctly?
jimmbo
Agreed i would be stunned, smiles a 70 /110 hp....i can see a 100 perhaps getting there however
Even a 99 in. 140 would be very hard pressed to get that RPM with a 21 on that hull, it might get to 5300-5400
flyingscott
I know people who have owned those boats and speeds with an 85 hp was the high 40s. I would check your tach again and GPS your speed.
Tail_Gunner
Is that gearing you posted accurate,by the book so to speak. I'm using a cell phone alot lately and can't access the boat library
I guess I should add a few things to this scenario, starting from scratch period. The engine is set far to low the cav plate is actually 1to 2 inches under the hull the engine spun the prop right to 6000 its set up very badly and will be tinkering with things next week...aka starting from scratch i was just taken back by prop and slip calculator so I started posting to get some insight on this small boat motor combo. Trying to make a educated WAG
Lol there's lots to this restoration and a $100 is a $100 need to keep close track of them
jimmbo
well the 70 hp 49.7 3 cylinder looper had this ratio for many years
Tail_Gunner
Thank you Jimmbo that pushes things to a 21 on paper just when I had decided a 19 would be a good guess. I have little experience with small boats and outboards but a 21 sounds well wisho meter comes to mind. So I think im going to the marine boneyard and find a 20 21 lift the engine get a good tach and see what happens.
jimmbo
Make sure your tach is accurate and set correctly, I say a 21 is too much prop for your boat, and still stand by my recommendation of a 17 possibly a 19.
ahicks
I'm not sure why he's asking Jimmbo. It sounds like his mind is pretty well made up and he's just trolling for somebody to agree with him.
