Starting in Gear?
Pikey2574
I have a 1968 6hp evinrude Fishman and a buddy was at the controls and started it in gear (forward). I had a few problems afterward with the motor seeming like it was reving up (could be something else or I could be hearing things)does starting it in forward hurt the motor? <br /><br />Thanks for the help<br /><br />Kevin
bubbakat
Re: Starting in Gear?
I to have a 6 evenrude 1970 I to have started it in gear but don't like to and haven't seen any effects by doing it.<br /> maybe someone on here smarter then we are can give us the low down on this :D
rolmops
Hello.<br />There should not be any bad side effects as long as it is in forward gear.If you do it in reverse you may find yourself in the bottom of your boat.
