starting issue - 2001 Four Winns 5.7 Gi-a
kzabrisk
Hi all,
Out on the lake for a week and about half way thru, the starter wouldn't turn over. Trying it a 2nd or 3rd time would usually do the trick. When it doesn't work, I notice that the volt meter goes all the way to 0 while the key is in start position. No click is heard. I pulled the starter and checked the solenoid a few times by putting 12 volts to the post, it worked every time. I'm thinking that it's starting to go. Is there a way to test it other than what I did? What else should I look for. My batteries are new this year and I've ensured they are connected well/tight - no corrosion.
KZ
kzabrisk
Re: starting issue - 2001 Four Winns 5.7 Gi-a
thanks Don! that post is a huge help. I haven't tried it yet, will tomorrow. One question - do you happen to know where the slave relay would be for my boat? I suppose I can just follow the wires...
