I hate starting a new thread but I may have landed on something:
'97 Evinrude 25HP 3cyl with rope start.
I was having issues getting the motor to turn over after rebuilding the carbs (the right way finally), inspecting all spark and ignition components and checking fuel supply. I probably should've done this a while back but I sprayed a little carb cleaner into the carb throats and wouldn't you know it... It started right up. Didn't even hesitate a bit.
So through lot's of reading I am concluding that this motor either needs a primer system installed (still trying to find how to do that) or I have a clogged idle jet in my carb. When rebuilding the carbs I used a new rebuild kit, soaked the carbs after removing all plastic and ran a fine copper wire through the orifices and then blew out with compressed air. So, either I missed a jet, a jet is still clogging somehow or I need to install a primer system.
Thoughts?
Thoughts?
