Hi all im new 1st post
I have a mark twain 1977, its got a gm 305.
Its been worked on for the last 2 years to restore it.
I have replaced the plugs wires coil starter battery and insides of the dist. and the carb is new quadrajet,
I checked and set the points properly,
It is sitting at about 5 oclock or so for the number 1 spark plug
It has correct firing order,
My problem is I am getting a weak spark, if I take the number 1 plug out and ground it, the colors light orange and I know we are suppose to get a strong blue or white.
I cant get the engine to start. I got a small backfire 1 time, frusterated as it is I need help, any and all suggestions will due.
I have tried to turn the dist, 180 deg. and all that good stuff, I have done some troubleshooting Im sure its got to be either dist, or ignition im guessing?
