oldprocraft
- Joined
- Sep 18, 2006
- 7
Hi,
Recently purchased an circa 1980 Mako with an Evinrude 150. Have done some work on it - new hydro pump, bilge pump and new battery. My problem is that when I try to start it with everything connected nothing works. If I connect the main cables to batt then engine/trim and tilt work fine. If I re-connect everything then everything works(trim/tilt gps radio) but as soon as I try to start it kills everything again. I've run through this a few times so I'm guessing some kind of short but why would it only happen when trying to start? In the process of trying to figure out what set of wires is causing the issue. If anybody has a suggestion I'd appreciate.
Thanks
Thanks
