starting isue
MIKEY*2007
have a 85hp 1979 200840r has a spark that gives you a little kick is this normal or should it boot the hell out of you if you hold a srewdriver on end of plug lead as motor won't fire at all not sure if it is getting fuel or not how to test pump outflow
MIKEY*2007
Re: starting isue
thanks for help but it does not tell how the fuel pump can be tested if it pumps or not to carby
Big flop
Re: starting isue
Remove bottom plug from carb float bowl &
Pump primer bulb to see if your getting gas
to & in carbs.
If your holding plug boot cranking you should
get a hard jolt followed by A son of a -----
Done that don't recommend it. :):mad::)
MIKEY*2007
Re: starting isue
Thanks big only got a small tingle does that mean a bad power pack
