bob johnson
- Joined
- Feb 25, 2009
- 4,306
as I cleaned out the leaves and power washed the boat, getting ready to have it soda blasted. I can see that the ribs down the middle inside the boat have VERY little clearance under them to allow water to work its way back to the bilge. thus any little debris clogs that space and water has to build till it goes over the rib..so you will eventually have 8 little dams of water.
what do you guys do about that?
on the 18 ft ss I had started to refurbish, I drilled a 1/4" dia hole above the lip and through the bottom of the dome of the rib to help water make its way back...theoretically I am weakening that...but not my much I am thinking..
is that something that has bothered any of you ?
bob
bob
