starting my 90 hp rebuild...caged bearing
johnson89
how do I replace the bearing in the cage,do they knock out from the inside out or other way around.....don't want to damage the cage....got the piston side done..i loaded pic but they keep disappearing
Faztbullet
Caged needled brearings cannot be repaired, either order new caged bearing assy or order loose cage and install new bearings...
johnson89
No Title
I got them out,and new bearing installed,they tap from top down,put on wood board with a back to keep it steady,then turn it over and snap in new bearing....got pistons in,going to set in crank wed. then I am stuck,,was sent wrong parts for crankshaft seals....going slow but slowing moving in the right direction...pics keep disappearing
