Alright, thought I'd seen the end of this forum (or is it, "my problems with my engine..."), but lo and behold....
Been trying to start my engine over the last week and no luck. I have crank, good juice from the battery, but it won't fire. It will tease me with a quick fire and die, but nothing after that.
Basically when I go to fire it, I get a lot of cranking early on (from a fully charged battery), but no actual fire. I will try and try, then eventually let it sit, try again with choking it (as I usually do to start it), then again without choking it, etc. It won't start, and eventually I lose battery juice, and have to leave it until I can charge the batter again.
The engine has ran like a gem in the past, but I have had consistent starting problems over the past two years. When I do have it running, it runs like a dream. Throttle is good, linkage, steering, in and out of gear, idle, acceleration, etc. The engine runs very well, but the starting is a big problem.
What I've checked thus far...
- the battery (brand new as of this season), when I crank it, obviously the battery loses juice, eventually not having enough to sufficiently crank the fly wheel quick enough, I have gone back and recharged the battery and tried without any luck, also tried jumping the engine with my truck (truck to marine battery to engine)
- the spark plugs, also brand new as of this season, also pulled the plugs to check for spark, and there is plenty of spark when cranking it to start
- the starter, was refurbished, brushes cleaned out early on this season, and works like a gem, however when I lose battery power, I lose starter power
- the choke, seems to work when I push the key in, I have also had somebody manually choke it (moving the rod between the two carbs up and down), but still no luck
- the carbs, I sprayed a carb-cleaner, "de-fogger" mix into the carbs early on in the season, so I'm guessing the carbs are cleaned out
- the primer bulb, I've pulled the fuel line after the primer, primed it to see if it is pumping fuel in, and it is, no problem there, also when I go to prime it before trying to start it, the bulb is nice and tight, I've also had someone prime the bulb while cranking it to see if that would do it but no such luck
Other than that, I'm at a loss. My next guess would be the fuel pump. I do not know exactly where it is, is the fuel pump the same as the fuel filter, is it the same mechanism?
Any other ideas, tips on what to try, things to look for, and check over, would be greatly appreciated.
Thanks in advance everyone!
Scott
Scott
