Hi,<br /><br />I am having an intermittent starting problem and have yet to isolate the source.<br /><br />When attempting to start I will get nothing except a very small (.1 to .5V drop) indication on the voltmeter. Engine does not turn over, starter does not click. This happens once in a while.. usually it turns right over and starts without fuss. After a few minutes of tinkering with wires (looking for problems) and cycling the shifter it will sometimes come back... But now its been a few days of repeated failed attempts.<br /><br />Electrical seems OK, showing over 12.5V, all electronics and tilt works. Checked starter for continuity and its ok. Tried another fully charged battery, same problem.<br /><br />Is there an cutoff switch malfunction or shifter adjustment out of whack here that could be causing this? Or is it the starter? Thanks for any advice..<br /><br />DC
