roger fernandez
- Joined
- Nov 30, 2004
- 30
Hi Folks,
I am having problems starting my 1995 150-hp Johnson motor and was wondering if I can get some help identifying what the problem could be.
The problem is as follow.
On Saturday, I took the boat out and when I went to start it, once I dropped it on the water, it wouldn't start, the motor will spin strongly with no problem, and the batteries were strong, but the motor would not start, even when engaging the choke by the ignition switch, so the next thing I did was to activate the choke manually on the motor (red lever to the up position), and when I did that, it hesitated a bit, but it did start, so I put the choke back to the automatic position (red lever to the down position) and the motor kept running with no problems, so on I went fishing the entire day, and the motor was turned off every time I stopped on a fishing spot, but it will start right up with no problem, however, the last time it turn on after a couple of minutes of running, all of the sudden it just died while the boat was moving, and it just wouldn't start anymore, it will spin strongly, but it wouldn't crank, this time not even with the choke engaged manually.
I already tried the following troubleshooting steps, with no luck.
1. Replaced the gas pump with a spare one that I have that I know it is good, but it won't start.
2. Used fresh gasoline, in case that the gas on the boat tank had water in it, but it wouldn't start.
3. I took down the choke and dismantled it to inspect it for any damage, but I couldn't see anything wrong with it. And I thought I may add that when I press down on the switch key, the choke makes the clicking noise, so that leads me to believe that the choke it is good.
4. I checked all 6 spark plugs to make sure they all had spark in them, while cranking the motor and they did.
5. I checked all the wires on the wire harness to look for any broken cables, but I couldn't find any broken cables.
6. The ignition switch, along with the entire wire hardness from the middle console going to the motor, was replaced brand new a couple of years ago, so I don't think the starting switch could be bad.
Given everything that I've already explained and troubleshooted already, can anyone please advise on what the problem could be here. Is there anything else that I should be testing or trying that I haven't done already.
Any help is greatly appreciated.
