big_johnst
- Joined
- Oct 4, 2003
- 14
My 1985 55 HP Mariner/Yamaha is hard starting. I am having to use starting fluid to kick it off before every trip which is about every two weeks. Once started it runs great and will continue to start without problems for the rest of the weekend. Since it runs fine after starting, I just chalked it up to the motor getting old. Now after reading on this site about the hazards of starting fluid, I would like to solve the problem.<br /><br />I use this procedure. Pump up bulb, advance throttle, choke, start. It use to work great but now when I pump up the bulb I hear a squirting sound like gas going into the cylinders. This doesn't seem normal. My guess is the motor is flooding because the float level is set too high. Also, the spark plug gap in my manual is smaller than the one NGK recommends on their web site. I have cleaned the carbs recently with no improvement. I am baffled. The motor used to start very easily. This is more of an annoyance than anything, but I would like to fix it. This motor is a corporate halfbreed. I have never been able to find a manual that specifically covers this model. The only manual that I have is an all models type. I used the instructions for the 40 hp for my carb cleaning. The float needle valves do not seem worn (no grooves, etc.). I have checked on a carb kit for this motor. It is $115.00, which seems pretty outrageous to me. especially since the only things in them are a couple of gaskets and the needle valve. If someone has ideas, let me know. It really pains me to take it to the shop.
