Starting problem
estedman
Cliff Notes:
1990 Merc 5.0 When I turn the key all I get is a click at the relay above the fuel filter. I think the Serial # is C869710.
I went to start my boat yesterday, Maxum 2500, and it fired for about a second and stopped(which is somewhat normal when its sat for a couple of weeks). It turned over a couple more times and it then acted like the battery was going dead and just turning over very slowly.
I went and got a new battery and now all it does is click when I turn the key. It sounds like the relay above fuel filter is making its contact when I hear the click. The relay looks like it has a red reset button on it, not sure if thats what it is.
Is this a starter problem? On a car I would say yes, but I'm new to boating so I don't know if there is another electrical problem elsewhere to look first.
Not sure if the process of starting the engine and the battery going dead is related/cause of the problem or just coincidence.
Thanks in advance for any help.
Coors
Re: Starting problem
Start by cleaning all connections from the battery to the solenoids and starter, then measure voltage at all places.
Ayuh,......... And Don't forget to Clean the Ground connections as Well......
