New to the forum and need help.
Starting Problem
Looking for help concerning a starting problem with a 85 HP Evinrude.
The Problem:
When the motor sits overnight the starter will not work, only get a click from
The solenoid. The battery is good. Good current going to Solenoid. Ground is OK.
Here?s the kicker, if when the starter does not turn, I turn the flywheel by hand for
A half revolution the starter will work. Also, instead of turning the flywheel, if I
Turn the shaft on the starter a revolution or so everything works fine.
I don't understand what the turning of the flywheel would have to do with
the starter.
Any help would be appreciated.
Ed
Starting Problem
The Problem:
the starter.
Ed
