starting problem
tim10034
hey guys 1996 volvo 7.4 efi...when i go to start it ,cold or hot, the engine fires up and then dies right away....if i fast idle it before i start it will stay on....changed sparked plugs and distrubitor cap, cleaned flame arrestor but still giving me the same problemm....kinda idles a little rough also any help ?????
Rickles
Re: starting problem
Sounds like you have an Iac problem(idle air control)You need to have the computer scaned for codes to see if the motor is going haywire or possibly something else like the tps(throttle position sensor).Look at all the vac.hoses and sensor connections first.Did the battery go dead recently?Some computer systems need to learn how to idle/run again after going brain dead.Disconnect the batt.and restart the eng.to "idle learn"the computer.
snapperbait
If your fuel is good and filters are new and clean, might look to the throttle position sensor, but that's only a guess.. Without checking for codes stored in the ecm, it's hard to tell..<br /><br />How did the old spark plugs look? Normal/tan , sooty black, oily black?<br /><br />Other things you might check are the plug wires.. Grab a volt/ohm meter and check the resistance of each wire... Suppression core wires do break down over time causing breaks in the core...
Northern Eclipse
Have you tried cleaning the throttle body, if you pull the air plenium off you will see a big butterfly, just in front of it there is a little hole , thats the idle bypass passage and it could be clogged which could cause stalling at start up, just be sure to use throttle body cleaner, you don't want to mess up the inside of the thottle body surface.
Cobra SX
Yes look to find the TB vent's and injector's <br />See if the are gummed/clogged up fuel loves to do that on a sitting TB or Carb.<br /><br />if you have the CP scanner Look for codes wrong
tim10034
well finally got a chance to start to work on the boat...cleaned out the throtle body with some cleaner and now it starts and idles fine....now if i can only get that dang fresh water pump off so i can fix it....well if it wasnt hard then i guess it wouldnt be fun...haha..thanks for the help
