Re: Starting problems after layover
I think the old gas is the key,did you drain your carbs before you stored it?
if not sounds like you need to run throught the carbs and clean them.
It takes very little crap in a carb to make you motor run bad/not at all.
Also put up model # so the pros know what they are dealing with but I would start with the carbs.
As far as adding new gas to old I do that every year,it only sits for 4 months so it isn't "bad" and I make sure I put in more new gas than there was old and we are only talking 2-3 gallons of old to start with.
Plus I always drain my carbs after the last trip, that is the key.
