Well I came back from deployment and tried to start my boat. It wouldn't even turn over but the starter was trying. I pulled the plugs out and found that the rearmost cylinder and the one forward of it had some in it as well. I remembered that I hadn't drained the motor but since it was over summer cracking the block with freezing wasn't a concern. I checked the oil and it's clean without a trace of water in it. Then I cranked the motor over with the plugs out and proceeded to cover myself, the boat, and my truck with 3 month old water that was full of carbon from the cylinders. Well after cleaning everything up and making sure the cylinders were dry and the plugs clean I tried to fire it up again. Still no start and it's getting gas. I picked up compression tester and the cylinders read 100, 50, 110, and 90 from front to back. I'm leaning towards the head gasket being bad but I wanted some more experienced people's input. I can do all the engine work myself so it would just be the parts and time that I needed. Anyone have something else I should check?
