uss cape cod
- Joined
- Apr 26, 2005
- 7
STARTING PROBLEMS
i am sorry about the first poster,just excited did not realies what i was doing,ihave a 1973 johnson,module # 115esl73m,115 hp v4 has rebuilt carbs,float drop 1inch,turn carbs upside down levelwithcarb,new power pack,new retifier,new plugs autolite2892,out the water with ears on starts up ok,runs good no misfire,nobackfire, timing is 5degress befor tdc,idles at about 1000<br />wil restart up with no problem,with out choking get the boat too the lake starts up fairly good<br />rund geed at idle, midrange and hi rpm all ok get to fishing spot wait 20-30 minutes hard too start tried with choking and without,will allmost drain battier becausing of long cranking some times big puff of smoke comes out when finall starts, will run good only hard too start when sitting for a while only at the lake thank you very much for lstening
