Today when out i stopped my boat. Tried to start it again and it kept making that noise as if your car was running and you tried to start it again, that screech noise.
So i took the cover off and turned the flywheel a bit then tried again and it started. I also watched it try to start with the cover off and it seems that when it just made the screech that the starter could not get any grip with the flywheel teeth.
So where do i need to change the flywheelk or the starter teeth? where do i find these parts?
