Hey guys,
Newbie here and don't know much out marine engines. I have a '78 Mercury 1150 115hp 6 cyl engine, serial number 5051734 with starting problems.
I recently aquired the motor from a fmaily member that had it for several several years. It has sat for several years without running. Recently like towards the beginning of the year they pulled it out of storage and tried starting it but they could not get it to start. It sounded like them that they were not getting a spark. They had the compression tested on it and it was great compression on all 6 cyl only varied about 4 psi across all 6cyl. The problem I have now that i have it, is that i can not even get it to turn over even by jumping it with my truck battery. I know it has spark because the dist. cap was off wheni turned it over a few times and i can see spark jumping across the terminals in the cap. When i turn the key all i get is a clicking noise at the starter. I pulled the starter off and tested it by hooking it up to a battery and it spins but it does not look as if the gear at the top spins up. But the starter does not engage or spin when hooked up on the motor. Any ideas? Is the stater bad or is it someplace else? Thanks.
Shaun (newbie)
Shaun (newbie)
