Howdy ...<br />I have just purchased a 1962 Glastron 16 foot Starfire with a 40 hp Johnson Sea Horse O/B motor that I assume is also from that era. I must check data plate on transom area bracket for serial # and model # , but I believe the first digit on the Johnson is letter " B " ( BDL ??-23 ??) <br /><br />Anyways, the boat has an electric key start,with choke button on boat instrument panel. <br /><br />There is a large un-labelled lever on the front of the Johnson motor by the Transom that can either be in the horizontal or vertical position. <br /><br />Two 6 gallon metal portable fuel cans connect via rubber fuel lines and primer ball .<br /><br />My questions is to engine starting procedure:<br /><br />Do I first place the lever in the vertical position ( fuel **** open ?? on the Johnson itself, then pump the primer line until hard, then go to the key switch and press the choke button while turning ignition key to " Start ? " <br /><br />Pardon me for this very basic question, but I am totally new to O/B's, having gotten this ole boat through individuals no longer able to advise me because of sickness. <br />I am using a 50:1 mix of oil/gas. <br /><br />Thanks !
