Jcris
- Joined
- Apr 23, 2016
- 466
My boat has an electric fuel pump that doesn’t get power until the motor builds enough oil pressure. I believe that’s normal. After the boat sits for a couple days it’s always difficult to start cold. To start it cold I crank the motor until the oil pressure alarm stops ringing. I then turn the key off and advance the throttle full twice to get some fuel in the carburetor. Then, with neutral bypass engaged , I advance the throttle about 1/2 way and try to start. It will usually start but run very rough until the choke opens. At which point it begins to idle smoothly. Does this sound right?
I don’t like how rough it runs initially
let me know what you think
thanks
thanks
