Starting System Basic Wiring Diagram
hardiek
Hello,
Can anyone point me in the right direction to find the basic wiring diagram for the starting system of an 1993 OMC Cobra 5.0? I am trying to trouble shoot the starting system.
Also, can anyone point me direct on what I should do prior to starting a boat that has been sitting for almost 2 years?
Thanks.
Kevin
Bt Doctur
Re: Starting System Basic Wiring Diagram
Generally speaking, most are like this
hardiek
Thanks for the diagram. Is it okay to jumper the starter direct from the battery? Thanks.
Bt Doctur
Depends what you mean by jumpering.A remote starter switch is better . Making sure there are no gas fumes present before making a spark is a whole lot better.
Exactly what dosent work?
hardiek
i am restoring a 1994 four winns and it currently doesn't have a throttle (which I am replacing) and the key switch cabling to the starter is currently disconnected (which I need to get figured out). So I want to start the motor up and need a temporary solution to use without the throttle and key switch cabling.
Thanks.
hardiek
By the way this forum is awesome!!!! Everyone is so helpful and without this forum learning to restore a boat would be extremely difficult. Thanks for all your help.
