Re: starts great, idles great, but dies when in gear
Two years ago I had to store the boat in a garage. It was an unexpected event that caused me to not use the boat. It had been running great up till then, this summer was first chance I have had to run the boat since that time, the bottom carb had gas running out the front of it. I could not get it to run. I assumed that the float was stuck or had a hole it. Tried tapping it, didn't work. put cleaner in it, didn't work. Took advice that a rebuild was needed. I did that and now it starts great, idles great but when you put it in gear and give it gas it starts to die out, I feel that I will have to remove the carbs again and look for some blockage, I feel I did a good job on the rebuild, what the problem was, it had a stuck float caused by the gas that was left in the carb during storage. If I can make an adjustment without taking carbs back off tell what to do. My manuals don't really have a trouble shooting section, it says to take to an authorized repair center. $45 AN HOUR, I'm looking for an alternitive. Thanks Tim
