I am purchasing a boat today and the outboard on it (8hp Nissan) starts and runs for about 20 seconds and then stalls.
That's all the information I have as of now as I haven't purchased the boat yet. I'm basically trading something of no value to me for it so I'm happy to acquire it even if the motor doesn't work.
My general mechanical knowledge tells me the Carb is stuck or it has a mixture problem. I'm just curious if anyone knows of any major problems that would cause the motor to run for 20 seconds and then quit even at full throttle?
I have never worked with a marine engine and I'm not a mechanic, but I figured I'd get it, go through a service manual and tune it up, clean the carbs, check out the choke, adjust the mixture, clean/change the air & fuel filters and it will likely run like a top.
Am I way off base here?
