colding
- Joined
- Apr 22, 2012
- 64
Hey guys, looking for some advice. Two weeks ago, took the family out for some fishing and crabbing. Motor started right up. I drove it at cruising speed for about 20 miles with a few stops in between. On the last stop, the engine would fire, but only run a few seconds before dying. Had my son try to keep pumping the bulb while running, but it would still die after 10-30 seconds each. Started looking at all my fuel lines and connecting to make sure I had no leaks. None found. Pulled the cover off the motor and notice once of the carbs had a leak around the gasket of the float bowl. We we able to get back to the landing (about 7 miles away when issues started) by running wide open for the 10-30 seconds it would run without dying completely. Luckily the battery held out for the 50 or so times I had to restart.
Get it home and immediately order carb kits for all 4 carbs. Everything arrives in a few days. Putting carbs back together I notice another problem. Most of the plastic float bowls are warped and won't seal properly. So, I promptly order 4 new float bowls. They arrive in time for the next weekend. Get all the carbs back on and confirm there is no longer a leak around the float bowls or anywhere else on the carbs.
Now, the issue is not fixed. Not only that, it seems worse than before. It will no longer stay running for more than a second at a time. It fire right up every time I turn the key, but dies almost immediately. I go buy an auxiliary tank with new primer bulb and fuel lines and hook that up in place of my built-in tank/fuel-water separator/bulb fuel lines just to rule out any issues there. Still the same issue. The bulb stays primed the entire time I'm trying to start. There is definitely fuel/oil getting to the carbs. The bowls are full of fuel when I remove them from the motor.
My best guess now is the fuel pump. But a new fuel pump for my motor is almost $400. I don't mind buying it, but I definitely don't want to if it's not the issue. I guess my questions are these:
1) How can I test the fuel/oil pump? I was thinking I could remove the output hose on top of the pump and try to start it and see if fuel shoots through it. But, even if it does, I don't know how much force it should be pushing through it.
2) If it's not the fuel pump, where else should I be looking?
BTW, this is a 2005 Johnson 90HP Saltwater series. Model #J90PLSOA. I've had the boat for almost a year and had it out almost every weekend since I bought it with no issues until now. Looking for any insight you might have. Trout season is here.
