State Towing Permits
jfaisten
I plan to tow my Trition 220 from Georgia to Michigan in early April. I reviewed the towing regulations in each of the states I'll be going through. My trailer and boat fall within the guidelines as far as width, length, hight etc. That means I don't have to apply for any permits, correct? Seems pretty intuitive but I want to be sure.
I posted this on the Hull Truth as well and received one response that indicated I'm on the right track.
Thanks
Re: State Towing Permits
Ayuh,.... If it's Not over 8', 6" wide, nor over 13', 6" tall,...
No, you don't need any Permits...
sasto
Now you have 3. I'm with Mr. Bond's son....Bond-o!
smokeonthewater
yep permits are only for vehicles that would otherwise be to big to legally be on the road IE, in layman's terms, taller, longer, wider, or heavier than a normal semi truck....
