I have a 2002 Merc 150 with a static flush port to connect a garden hose. I have always used this flush port without running the motor. A friend of mine says it is ok to run the motor while connected to this. I do see water coming out the pee hole, and lower portion of the motor when I flush the motor. I though I read somewhere that the motor could not be run while using this flush port? When ever I so start the motor I use flush muffs. My question is can you run the motor off the static flush port or will it eat up the water pump impeller?
