Re: Stator AC or DC current
The voltage from the stator that is used for charging the battery is about 20vac at idle and upwards of 35vac at WOT.
This voltage can be directly read by any voltmeter set on the AC selection. You do not need a peak reading meter for this voltage.
The truth of the matter is that you only need a peak reading meter (DVA) when you are trying to read AC voltage pulses like the output of the pack, or the output of the timer base.
You can read the battery charging coils, the power coil, and the charge coil directly. It may not have the same spec voltage tho. The DVA is rectifying that voltage and you are reading peak DCV on the DC setting remember.
Now...can you calculate the AC current in the stator by measuring the DC current at the output of the rectifier?
Good question.....but you do not know which type of rectifier is being used in the reg/rect circuit.
Is it a bridge diode configuration, a full wave diode, or a half wave diode....I do not know.
Without knowing, you cannot calculate input vs output current. I would think that it is a very safe bet that the output current is just about equal to the AC current in the stator windings. After all, that is the source of the generated current, and I doubt that the reg/rect reduces that very much, because of the sheer heat that would be generated by the reg/rect just to do the reducing of current or voltage.
I do know it gets hot...but I don't think they would have designed a circuit to deliberately dump a bunch of useable current. There are SOME losses due to the regulator operation, enough to generate heat.
