Stator issue
mav6759
I have a 2005 mercury 90hp 2 stroke, I'm having an issue with the motor restarting after the motor is warm..I would stop and fish for about 20 mins, and when I try to restart it takes a while to get it started, but she will start. I was thinking of checking the stator. But the motor is still firing,,, however, I was thinking that once the motor got warm, the spark got week (or no spark at all) causing the motor not to start. When I looked at the stator it seemed ok from what I could see. But the wiring felt like spaghetti, its like there's no wiring in the jackets. The stator has 4 wires along with the switch box. it is wired as follows:
Stator Switch Box
Black to Black
Purple to Gray
Light Brown to White
Dark brown to Dark Brown
I tried to tested the resistance with my multimeter 200ohm..... the black from the stator to each of the 3 wires of the staor and I got nothing, if I did it right... The motor still starts and runs but that is this only problem I have with the motor..Does anyone know if I checked the stator correctly or why the wires are like spaghetti.
Thank's
Mav
Ayuh,...... Check to see whether it's gettin' fuel,.....
