Stator meltdown
BobList
Now, I'm hoping I've been able to upload some pics...
I looked under the flywheel today, saw a melted plastic piece hanging down.. pulled the flywheel, found magnet loose, hanging down about 1/4".. the flywheel seemed to be stuck on the area I found the plastic insulation melted on the stator.. the engine runs ok, tach is screwy, though.. I am going to clean the flywheel, reattach the magnet (still one piece), and hope for the best.. I am consider using 3M trim adhesive ( aka Gorilla snot ) to do this.. do you experienced guys have a favorite glue?.. or is that stuff ok...
Now, the 5 melted poles start with the green/yellow wire at the 7 o'clock position, and are counterclockwise from the 7 o'clock position. All the rest look ok. The copper wiring is NOT melted, but if the pics work, you can see where melted insulation actually bridges a couple of poles.. it's insulation, so I doubt it could short anything. I will be researching tonight this forum to properly ohm out my stator, but any suggestions or tips are welcome..
Bob List
I'm starting to feel like an experienced Force owner now.. one thing after another.. Like an old Volvo.. damn thing'll run all day, but needs constant repairs!!
fucawi
Banned
Re: Stator meltdown
glue in magnet with something that will stand the temp ..not 5 min epoxy....well the coils ..they either work or they dont .....looks like the battery charging coils to judge by the thick wire
