Hello Guys I am hoping that yall can help me with this. I know that you can, who am I kidding. I have a 89 Force 125. While coming in from a good day of fishing here in northeast FL. I was in a no wake zone and idling by some boats that my sone wanted to see and the engine died and would not restart. We got towed back by a little jon boat with a 9.9hp. Talk about the talk of the ramp. We got it loaded and back home. I worked on it and thought that it was a fuel problem so after tweaking it for a bit, I got it going, not perfect but running. Took it out to test and further tweak it and could not even get up on plane. sounded and acted like it was running on two cylinders.
Got it home, and tested the spark. No spark in cyl 1 and cyl 2. I tested the packs per the trouble shooting guide at CDI electronics' website. The resistance checked out and then I swaped the blue and yellow wire from the stator to the bus bar. Cranked the engine and got spark in cyl 1 and cyl 2 but not 3 or 4. So by swaping the leads leads me to believe that since the problem followed the swap that the problem is in the stator.
Put in another stator that I had in the garage from a parts motor and came up with the same problem. Is it possible that the stators has the same problems.
Here is what I need help with
1. Part number for the stator. The numbers on the stator that I have are FCC3007L 3792 (but do not cross with anything I have found).
2. How does one test the stator and see if it is good?
3. What else could cause these symptoms?
Thanks for all the help and look forward to hearing from yall soon.
JJ
JJ
