Re: stator or rectifier for charging problems?
I also seem to have a charging cicuit problem. My daughter called in for a tow back to town with dead batteries, (she was running on both and stopping and starting the '87 150 XR2 a lot to pick up and drop off skiers and tubers). The rectifier tested bad so I replaced it. Starts and runs fine, but no guages or tach. So I replaced the stator as well. The new stator made no difference. I have continuity from the positive post on the rectifier to the positive post on the tach with the key switch turned all the way over to "start", but not with the key switch in the "run" position. To complicate matters this engine has a two post voltage regulator mounted on top between the heads. My Seloc manual makes no mention of this voltage regulator, and I have no idea how to test it. It shows 20.30 ohms across the terminals. I tested one on another '87 150 and it showed 20.05 ohms. Anyone know how to test this thing, or what the resitence value should be?<br />Any ideas? Right now I'm thinking the voltage regulator is bad, or maybe the key switch? My seloc manual says to test the charging circuit by using a special adaptor to allow a VOM type ohm meter to read the positive battery conection. I don't have this special adaptor or a VOM meter which could stand the starting amps of the circuit using it directly. My amp probe reads 2.5 amps at low idle and about 5.5 amps at high idle. this seems low, although it may not be accurate as the amp probe is designed to read AC not DC. BD
