Re: stator problems
The tracer colors on the wires are as important as the base color. I'm betting you're talking about the idle stabilizer, and the wires would be red with white tracer and white with black tracer.
Anyway, You have a 9 amp system. Stator part number would be 398-5454 A7.
For sure , CDI 174-5456 will go, and probably the CDI 174-5456-16. The only question is whether it has the old flywheel on it that might not clear a 5/8" stack.
You could probably get away with putting on an398-5454-A32 or equivalent 16 amp, 1/2 inch stator.
You probably have flywheel 257-7555A3 or 257-7555A8 (1/2" stack) on it. With flywheel 257-7555A9 you could put any 9 or 16 amp stator under it, either 1/2" or 5/8".
Heck, if it were mine, I'd try any 9 or 16 amp stator that was cheap, and if it didn't quite fit, go find a used 16 amp flywheel from a later engine. (would be the A9). Then you're home free for anything in the future.
hope it helps
John
