Stator specs
BobList
Does anyone here have the resistance specs to check a stator OFF of the engine? My manual just tells me how to replace it, not check it. I need specs.
It's a 1988 125 Force, 20 pole stator. My manual doesn't clarify the colors, either.
Thanx,
Bob
pnwboat
Re: Stator specs
680 - 850 OHMs between the pair of Blue and Yellow wires that connect to each CD pack. If memory serves me correctly, the first pair should be marked 1 & 2, second pair should be marked 3 & 4.
BobList
Re: Stator specs
Thanx, man.. that helps a TON!!!
do you know about the green/yellow wires? or is continuity in any form ok for them?
Bob
BobList
Re: Stator specs
thanx again! I'm writing these specs in the manual as I type this post!
Bob
