Stator Sticky Stuff
DCSLADE
(1973 50HP Evinrude)
I have brown sticky stuff dripping from the stator on to the top of the block. (back only)
Is this a sign of overheating or just an old stator? Is there anything I can do to stop it? It seems to function fine.
Thanks
Walker
Re: Stator Sticky Stuff
Its an indication of your stator on its way out. You can't fix it to my knowledge.
F_R
'73s did that. You are lucky you got so many years out of it. Replace stator. New ones are better.
DCSLADE
Does the entire ring assembly need to be replaced or can just the leaking module be replaced?
Thanks
Joe Reeves
The replacement of the entire unit is required.
papasage
i have several used ones if you need one .
DCSLADE
I will need one. The one I have functions fine and I wouldn't have known there was problem until I pulled the flywheel. Are the used ones the same age and likely to have the same problem? (Spending a couple hundred on a new one doesn't thrill me either!)
Thanks
papasage
i bought several old 50 hp johnson and evinrudes for parts .don need all will sell some parts
papasage
this is one of several i have
