Incorrigible
- Joined
- Jan 5, 2009
- 111
Engine: J225TXESS (1990 225hp)
Have run diagnostics on stator which indicate the output is less than called for. Output is below the 130 volts minimum.
The tach on this engine only reads to approx 2000 rpms and then returns to zero after the engine RPMs increase.
Additionally, this engine will start to misfire at (guessing, no tach) 3500 or so RPM's. Having gone over the fuel system, and regapping the plugs, checking compression, testing SLOW ops, I'm curious:
Does the stator charge the battery (I believe so) AND ALSO provide the current for the coils (I believe????) If so, is there a possibility that the failing stator could be causing the engine to miss at higher RPM's due to the higher demand of the six ignition coils?
As well, could a failing stator be a source of the problem for the tach at higher rpms?
Thanks
Thanks
