Stator Test Help !!!!!!!!!1
This Is How I Tested It , My Ls Ohms Are 6.300 Volt Meter In 20k On Dial /
Hs Is 152.1 Volt Meter In On The Dial 200
My Volts Are Ls 275 Hs 36 My Volt Meter Is In V~ 500 On The Dial
So Are My Ohms Good And My Volts Way Off ?
Im I Using My Meter Right?
Last Year I Had To Replace My Switch Box Is This Why ?
Thanks Guys !!!!!!!!!!!!!!!!!!!!!!
Laddies
Banned
Re: Stator Test Help !!!!!!!!!1
I can't tell how your meter reads but here are the spec.
FLEX PLATE FLLWHEEL--OEM stator
Blue to blue/white---5000 to 7000ohms-----180+volts
Red to red/white----125 to 155ohms--------25+volts
CAST VENTED FLYWHEEL--OEM stator
Blue to blue/white---3250 to 3650ohms-----180+volts
Red to red/white----75 to 90ohms----------25+volts
CDI stators OHM differantly but use the same voltage.
