1974 Merc 402 40hp Canada motor. I suspect a problem at either the stator, switchbox or wiring harness. The last 3 times out, after 10-15 minutes the motor started stumbling like the key being turned on and off after about 15 minutes of running. Those first 10-15 minutes everything works perfectly. This started with just a once in a while hicup one day and the next couple times out it does great for 10-15 minutes then stumble sharply like crazy at anything above 1/3 throttle but would idle back to the dock no problem. Last time out I adjusted idle mixture and installed a new throttle cam which I broke while tinkering. While on that test run we didnt even make it back to the dock but after 30 minutes the motor started up and ran great and I put it on the trailer in less than 5 minutes. That was all last fall, winterized and havent been back in the water since.
Question 1.
When I test the stator with the ohm check. Do I keep the wire (red) from the stator connected where it connects to another short red wire at the screw terminals which then goes to the switchbox? Or, do I need to disconnect the red stator wire at this screw? I believe I disconnect it to ohm test shouldnt I? For a volt test while running keep hooked up and test at the screw?
Also does this red wire test both the high speed and low speed windings of the stator? Or is there another way that is a more complete test of the stator with the other wire from the stator? Seloc says just test the red wire for this motor/stator.
Question 2. Testing the main wiring harness that plugs into the side of the motor. When ohm checked with the key "on" and the battery disconneted the center plug (7 hole plug) makes my ohm needle bounce around the scale. Whats this indicating? Could this be my problem or can this motor run without the harness hooked up.
Thanks, Im electron ignorant.
Im pretty sure this problem is electrical. I have new fuel, good vents, new fuel lines, new bulb and trying pumping it doesnt change engine speed at all. Compression was tested right before my problems and was said to be at 120 on both cyl but I did not test it myself. I have not removed carb.
Thanks
Question 1.
Thanks
